Ever since I got the Experia V10A I have been very impressed with its wireless performance but I am really disappointed that it does not have any 1000Mbps LAN ports. The ports are limited to 100Mbps which is very disappointing because I have 500/500 Fibre but if I connect over LAN this speed is limited to 100/100 because of the slow LAN ports in the box.
Does KPN have any other routers that are built better to handle the speed?
Hello @DanielNL
It does have 1000Mbps LAN ports.
What UTP cables are you using? They must be Cat5e or better to support 1000Mbps.
Or do you have a switch of other device behind the V10a which only support 100Mbps?
Hi @DanielNL
Good to hear that you are impressed with our wireless speed. In the link you can find extra information about different types of cables and which speeds you can expect per cable.
Welcome to the Forum.
@GeSp  has rightly asked what kind of cable you use. Perhaps useful to dive in:muscle_tone2: . In this link you can find additional information about cables and what speeds you can expect from them.
I hope that will help you!
Hello @DanielNL  Or the used devices do not support higher bitrates than 100Mbit/s.
CC: @Denise. and @GeSp
