I have a subscription of 200mbps a month and I had this problem a month ago. My connection is too slow. And also my wifi. Can you help me with this matter?
Welcome to the forum
With a subscription of 200Mbs, this is a very disappointing result  You said your connection is slow and also your wifi, have you run this test via wifi or via a cabled connection?
Can you please update your profiel and give me a heads up if you’ve done so? I'd like to run a diagnostic on your line, to see if I can find any errors!
Welcome to the forumÂ
I used a cabled connection with this result. And much worse with my wifi. It doesn’t even work well.Â
Thanks
ThanksÂ
Sure. Already did.Â
Thanks
There's something wrong with your connection, and you're receiving only half of the 50Mb's that goes with your ‘Internet and TV Basic’ subscription. This isn't something you can fix yourself, neither can I fix this from the office. I've scheduled an appointment with a mechanic at the first possibility, which is today between 14:00 and 16:00. The problem seems to lay in our infrastructure, so the mechanic probably does not need to visit your house. However, it is necessary someone is at home during the appointment, because the mechanic will call to check if everything is working. Is this a suitable time? Or do you prefer another moment/day? And is it alright if the contact number we use is the one ending with 116? Or should we call another number? If so. please leave this number in the ‘opmerkingen’ field in your profileÂ
ohh I see. Today is possible. I’ll give a new number. Wait a sec.
I've changed the number! Will you let me know if the mechanic has fixed the problem?Â
That would be awesome. Thank you!
Hi
I haven’t heard from you again, so I’m assuming don’t need any more assistance. If you have any other question, please let me know!
