What APN configuration do I use in a Raspberry with a KPN simcard in Spain?
  • 14 February 2024
  • 138 keer bekeken
Hi, I have a Raspberry with a 3G router inserted, I'm in Spain.
I have a KPN SIM and I would like the raspberry to have internet from the SIM. I have tried with a Spanish Movistar SIM and it works fine. I put the KPN SIM in a mobile and it works correctly. But when I put it on the Raspberry and after configuring all the APN options I have seen on the internet (portalmmm.nl, internet, KPN4G.nl + User, Pass, PIN: empty) I cannot get it to connect to your company KPN, it keeps trying to connect.
Do you have any idea what could be happening to me?
Thanks in advance,
Edu
2 reacties
GeSp
Forum|alt.badge.img+19
  • 6480 reacties
  • 14 februari 2024
Hi @EduSistec
I found these setting, maybe they also work on a Raspberry:
  • Naam: KPN
  • APN: internet
  • Proxy: Niet ingesteld
  • Poort: Niet ingesteld
  • Gebruikersnaam: Niet ingesteld
  • Wachtwoord: Niet ingesteld
  • Server: Niet ingesteld
  • MMSC: Niet ingesteld
  • MMS-poort: Niet ingesteld
  • MCC: 204
  • MNC: 08
  • Verificatietype: PAP
  • APN-Type: internet / default
  • APN-Protocol: IPv4
  • Roamingprotocol voor APN: IPv4
  • 1 reactie
  • 15 februari 2024
Hello,
Thank you very much for the answer.
Attached document where you can see the router parameters that can be modified. In the document there are the KPN configuration and the Movistar configuration.
It can be seen that most of the parameters you indicated do not exist.
Some idea?
thank you,
Edu
