Can I use a TP-Link Archer AX23 with my KPN connection?
  • mei 10, 2023 9:09 a.m. UTC
  • 8 reacties
  • 434 keer bekeken
Can I use TP-Link Archer AX23 router with my KPN internet connection?
Beste antwoord door wjb
If you have a fiber connection and you don't have TV through KPN then this is perfectly possible.
Please note that you will have to setup the pppoe connection on vlan 6 but that can be configured in the Archer AX23.
8 reacties
  • mei 10, 2023 9:34 a.m. UTC
  • mei 12, 2023 5:15 p.m. UTC
@wjb Hi,
I installed the router and make all the steps correctly but the internet light in the router is red from the beginning of the the installation till the end, do you know what can I  do in this case please?
  • mei 12, 2023 5:25 p.m. UTC
Can you show a screenshot of your WAN configuration?
  • mei 12, 2023 5:43 p.m. UTC
I can not now but all lights were green except the internet light is red all the time.
  • mei 13, 2023 9:12 a.m. UTC
The first one is when the router is connected directly to the modem and the second one wen the new router is connected to the old router.
  • mei 13, 2023 9:17 a.m. UTC
You have set the connection type to Dynamic IP but you need to use the connection type PPPoE.
  • mei 13, 2023 9:42 a.m. UTC
the router detected automatically, but even even when I set it to PPPoE it asked me about email and password but nothing happen after.
  • mei 13, 2023 9:53 a.m. UTC
I assume you connect the Archer directly to the NTU/ONT and not to the Experia/KPN Box. Is that correct?
Are you sure that you setup the pppoe connection on vlan 6?
The pppoe login (user/password) can be anything as long as so thing is entered.
