IPv6 settings for Unifi Dream Machine
  • jan 2, 2024 12:07 p.m. UTC
  • 12 reacties
  • 4038 keer bekeken
I haven’t found clean mentions of how to get IPv6 work with fiber connection to UDM, so here are screenshots of working settings.
WAN settings:
LAN settings:
After setting that up and reconnecting to the WiFi, IPv6 test shows native IPv6 support for my laptop.
12 reacties
  • apr 9, 2024 10:12 p.m. UTC
DmitryV, echt super bedankt voor je post, kan je echter nog toelichten wat er achter de witte vakjes moet staan. Snap dat je dit verborgen hebt omdat het persoonlijke gegevens zijn icm met je link local IP.. Maar hoe moet ik achter de IP gateway/subnet getallen komen die op op mijn glas-aansluiting voor een werkende IPv6 zorgen?
IPv4 werkt naar behoren rechtstreeks op mijn Ubiquiti gateway Ultra trouwens.
Zou graag IPv6 ook nog werkend krijgen.
Alvast super bedankt, Gr Nico
  • apr 10, 2024 6:40 a.m. UTC
IPv4 and IPv6 address can be seen at mobile KPN app → Internet → IP address.
In the internet, it can be found at https://mijn.kpn.com/#/producten/<your internet product id>/ipadres
Please let me know if you wouldn’t find it.
  • mei 10, 2024 10:52 p.m. UTC
For the LAN settings I set “prefix delegation” and select “primary (wan1)” on my uxg-lite. this works. I see the ipv6 address as shown in my “my kpn” portal.
  • mei 11, 2024 9:39 a.m. UTC
To see if it really works you need to visit https://ipv6-test.com in browser other than Safari (due to it’s Private Relay feature masking your IP and providing IPv6 address even if you don’t have it) and check if you have IPv6 “Supported”. and IPv6 Type set to “Native IPv6”.
  • mei 22, 2024 9:56 a.m. UTC
This works! Thank you so much!
In the overview window on my Cloud Gateway Ultra Unifi console, the correct IPv4 address is listed, as handed out by KPN. There is no address listed under IPv6 though, even though I’m getting an 18/20 score on the IPv6 test site.
Does the unifi console show an IPv6 address for you?
  • mei 22, 2024 10:10 a.m. UTC
No, because unlike IPv4, your devices inside the local network, including your laptop, are supposed to receive their IPv6 addresses, so there is no single address on the router. A prefix is allocated inside the network, and then each of your devices gets an address within that prefix.
Score on the test site doesn’t matter, what matters is shown on the screenshot above. If for you it looks similar, everything is set up correctly.
  • mei 22, 2024 3:15 p.m. UTC
What @snake06 says works for me, no need to manually assign the LAN range. After turning on the WAN settings and Prefix Delegation under LAN a /64 out of the assigned /48 will automatically show up in the interface and addresses from this range will be assigned to devices on the network.
Most test are green on (in Chrome, my Firefox doesn’t like IPv6 for some reason)
WAN settings:
LAN settings:
  • mei 23, 2024 9:19 a.m. UTC
Thanks a lot for the screenshots, @Cyzor! Your path is easier and works as well.
  • mei 24, 2024 1:55 p.m. UTC
Thanks for the updates! Much appreciated!
DJR
Helper
Forum|alt.badge.img+2
  • jul 4, 2024 2:47 p.m. UTC
Dank voor de guidance. Ik zie alleen in het Internet status scherm op mijn UDMSE niet dat KPN een IPv6 adres terug geeft of is dit niet relevant?
  • jul 4, 2024 7:09 p.m. UTC
Same here. Alles werkt maar er staat geen IPv6 adres, al heb ik er wel 1.
  • jul 5, 2024 1:45 p.m. UTC
It doesn’t matter; the only thing which matters is that when you connect to your WiFi, your laptop and phone get an IPv6 address. With this setup method, the router doesn’t have IPv6, at least not on the WAN interface.
