LAN speed limited to 100 Mb/s
  • sep 2, 2024 9:43 p.m. UTC
  • 123 keer bekeken
I have a fun issue if I connect my PC to the KPN router via LAN I get 920mb/s but if I connect that same cable via a second router or a LAN splitter the PC the speed drops to 90mb/s on LAN.
The wifi is running at 700-800mb/s on the same LAN but the best I can get the PC is to 90mb/s.  I tried to adjust the Ethernet connections (speed & duplex) from Auto but I can only set it to 100 mbs not 1.0G as a value.
The link speed receive/transmit seems to be defaulting to 100/100 mbps if I run the LAN cable into any other device such as LAN/Splitter.
Beste antwoord door DaveA
Then there is something in your network that has a maximum speed of 100 mbits. The switch, or something else for example. Because it’s not the PC, the modem or the Ethernet port
DaveA
  • sep 3, 2024 5:27 a.m. UTC
Hi @David Iwanow, what happens if you connect the PC directly to the modem?  So without a switch etc in between.
  • sep 3, 2024 5:42 a.m. UTC
Greetings, so directly connecting PC to Lan gives full speed 1Gig link speed which makes it all very weird.
DaveA
  • sep 3, 2024 5:47 a.m. UTC
