Port 44158 + Fixed IP for my Helium miner
  • jan 25, 2022 1:08 p.m. UTC
  • 446 keer bekeken
Hello,
I own a Helium miner which is currently relayed. In order to fix this, I need to set up a fixed IP for this device + open port 44158.
I’ve followed directions given in the forum:
  • Port Forwarding → Application Configuration → Create New App Name with protocol TCP and ports 44158
  • Port Forwarding → Port Forwarding - IPv4 → Create New Item with LAN Host as IP shared by Helium network linking to App Name created in step 1
  • I have the device connected via ethernet so for a fixed IP, via LAN Settings, I´ve selected my device and switch on Fixed IP-Address by DHCP binding. The IP Mode changes to static.
Following these steps, the port 44158 for my device is still closed, am I missing anything?
Thanks for your support!
Welcome to our forum @JavierPerez! Could you let me know which KPN Experia Box you have currently? If you have a Box 12 could you check out this topic that dealt with a similar issue? It is in Dutch but you should be able to use Google Translate. Just type the URL in the search bar and it should translate the entire page.
2 reacties
Bram van KPN
Forum|alt.badge.img+17
  • jan 27, 2022 7:12 p.m. UTC
  • jan 27, 2022 7:21 p.m. UTC
Can you show us some screenshots of the settings you have changed on the Experia/KPN Box is order to be able to connect the Helium miner.
