Problem with internet, connection sometimes disappears for 30 minutes to an hour
  • mrt 21, 2021 9:37 a.m. UTC
  • 1 reactie
  • 34 keer bekeken
Dear, kpn
We have problem with the internet. Several time per day our internet disappear (30 minutes - 1 hour) and it’s very annoying. Also our internet speed should be 50MBit but usually test show only 15MBit.
Could you please help us to solve this issue!
Regards,
Anatolii
Hi @Anatolii, welcome to our forum!
Are you experiencing this issue on Wifi or with a wired connection? In the case of Wifi I recommend our wifimanager this should have a solution for every situation!
If you're experiencing this on a wired connection I can take a look from this end. Could you give your modem a factory reset, update your profile and let me know?
1 reactie
Thomas van KPN
  • mrt 23, 2021 10:17 a.m. UTC
