Problem with setup Ubiquiti AP Unifi U6+ 3.0Gbps with Box 12
  • mei 6, 2024 6:27 p.m. UTC
  • 180 keer bekeken
Hey All,
I'm relatively new to the Netherlands, so I haven't quite picked up Dutch yet.
I'm having trouble connecting my new Ubiquiti AP Unifi U6+ 3.0Gbps with KPN  Box 12. Despite having superwifi 2, I lack power outlets in my ceiling and ports in my walls. To address this, I bought the Ubiquiti AP Unifi U6+ 3.0Gbps along with the Ubiquiti POE Adapter(POE-24-12W). However, even after connecting and plugging in the POE, my Ubiquiti AP isn't functioning. should i do anything else to make it work or buy any other equipment ?
Beste antwoord door Anonymous
Hello @Sina1961
Did you really buy a 24V PoE power adapter?
The U6+ only supports 48V so you need to buy a 48V PoE adapter.
See the specs here: https://eu.store.ui.com/eu/en/collections/unifi-wifi-flagship-compact/products/u6-plus
2 reacties
  • mei 6, 2024 7:25 p.m. UTC
Hello @Sina1961
  • mei 8, 2024 4:46 p.m. UTC
I purchased the right poe injector and problem resolved, thanks for your help🙂
Hello @Sina1961
