Question on pppoe username/passcode of fiber using own router
  • aug 17, 2020 8:43 p.m. UTC
  • 10 reacties
  • 2349 keer bekeken
Hi all
I am the few using english to ask questions, hopeful it won't bother everyone too much and get some help.
What internt i have from KPN:
1) Only internt, no telephone or IPTV;
2) The internet setup at my place is: fiber --> NT --> Experiabox v10
What I want:
1) I would like to replace the Experiabox v10 with my own router (xiaomi ax1800)
2) If this works, i would like extend to mesh with another ax1800/ax3600
Why:
1) I notice that the internet is not powerful for all devices used now, especically work from home (3 cellphones, 4+ PCs, 1 NAS, 20+ home devices, and lots of video calls everyday), I suffers several internet crashs during daytime, and unstable connections.
2) I have tried keep the Experiabox cool, away from sun, separated 2.4Ghz + 5Ghz, added extra rounter..., not satisfied.
What problem:
1) I tried configure my own router with pppoe, the username is copied from the Experiabox v10, aa-bb-cc-dd-ee@internet (mac address of Experiabox v10), but dont know the passcode?
2) Read lots of discussions here and netwerkje.com, tried with 'ppp', 'kpn', or 'random', does not work.
Thanks for any suggestion in advance!
Beste antwoord door wjb
So I need to setup my own router to vlan 6 for pppoe?
That's correct.
See https://kpn.com/eigenmodem
Google translate:
I have (bonded or vectored) VDSL2, VPlus or FTTH Fiber-optic internet
 Internet
  • PPPoE over VLAN 6 (802.1q).
  • PPPoE authentication PAP with a username and password (eg internet / internet).
  • Maximum packet size (mtu) 1500 bytes (rfc4638)
  • Obtain IPv4 address + DNS servers via PPPoE
  • IPv6 address range + DNS servers (IPv6) via DHCPv6-PD request (in PPPoE). Using an address from range for router.
10 reacties
  • aug 17, 2020 8:50 p.m. UTC
I don't know what the question is but I assume you face difficulties in setting up a pppoe connection.
The pppoe connection needs to be setup on vlan 6.
The username and password may be anything as long as both are filled.
  • aug 17, 2020 8:59 p.m. UTC
Hi, thanks lots for your fast response!
  • aug 17, 2020 9:06 p.m. UTC
That's correct.
Google translate:
 Internet
  • aug 17, 2020 9:07 p.m. UTC
That's correct.
Google translate:
 Internet
Great thanks!
  • aug 19, 2020 8:28 a.m. UTC
Thanks wjb  again.
I have successfully replaced the experiabox v10 with my own router (xiaomi ax1800) and here I share some tips if anyone wants to do that, it is not very easy but takes a bit time to do that.
  1. Get the access to the root of ax1800 (google with ax1800, vlan tagging);
  2. Using WinSCP to login  and in the file ‘etc/config/network’, modify the ifname ‘eth0’ to ‘eth0.6 ’ (2 locations)
  3. Save and quit
  4. Restart the root,
  5. Then, choose pppoe in the router, fill the username and passcode: aa-bb-cc-dd-ee@internet, ppp or whatever.
  6. Done!
The improvement:
  1. Way faster and more stable connection with loads of devices.
  2. It covers every corner where was no sign before.
  • aug 19, 2020 9:37 a.m. UTC
Good to read that managed to connect your own router.
I assume that you have an Internet only subscription (no TV), is that correct?
  • aug 19, 2020 9:57 a.m. UTC
Yes. I only have internet. But I have also checked, it is possible to put a extra switch and TV and telephone can be adapted.
  • aug 19, 2020 11:20 a.m. UTC
For television there is much more to configure from which I doubt if the xiaomi will support it. For IPTV from KPN the router must be able to connect as a DHCP cliënt to vlan 4 as well and it must have an IGMP proxy server that can connect on vlan 4.
If you want to learn some Dutch or if you trust Google translate then see "Use your own router behind an Experia Box".
  • aug 19, 2020 11:30 a.m. UTC
Thanks for the reply and information.
Yes, I also went through that article.  It is very useful.
The xiaomi ax1800 is based on open-wrt and I found some successful examples from internet, but I have not tried yet. I will post here if I make some attempts.
  • feb 8, 2023 5:30 p.m. UTC
Thanks wjb  again.
  3. Save and quit
  6. Done!
The improvement:
2 years later this comment helped me haha, thank you!
