Receiving internet with the KPN Box 12 via an RJ45/ethernet connection
  • August 30, 2022
  • 11 reacties
  • 609 keer bekeken
Hello, everyone.
Starting from today, my home connection with KPN should be activated.
However, it does not work and it could be possible that I have a problem with the modem.
In my house I have just two kinds of internet/phone connections: one with the coaxial cable, and one with the ethernet (RJ45).
In order to connect the modem to the phone line, I am connecting the RJ45 cable to the modem (to one of the ethernet ports - I have also tried the WAN port, though).
Should I receive internet in this way?
Otherwise, I believe I should give the modem back and (try to) end the contract with KPN…
Thank you very much in advance.
Beste antwoord door Xemnad
Dear @RBxx , indeed, inserting the cable on the right everything is working!
Thank you very, very much for all the help! You saved my day!
(Probably I was just too stupid to understand, or try, all these things!)
11 reacties
  • August 30, 2022
Hello @Xemnad can you please place a picture of your connection within this topic?
RBxx
  • August 30, 2022
Hi @Xemnad , only if you have a glass fibre connection the KPN modem is connected via the WAN port. Otherwise you connect the phone connection to the DSL port via a RJ11 connector.
The phone connection normally looks like one of these:
  • August 30, 2022
Or:De Glasvezelmannetjes | KPN Community
  • August 30, 2022
So, here are the cables I have
and here is what I was trying to achieve:
…but I have also tried the Ethernet ports - are they just of output?
Unfortunately I don’t have an RJ11 connection available…
RBxx
  • August 30, 2022
Hi @Xemnad , I think the white box just visible bottom right on the first picture looks like the connection to use. Connect the KPN Box port DSL with a RJ11 cable to this white box.
Didn’t you receive a set of cables from KPN?
  • August 30, 2022
Oh, I didn’t even notice that the other box was also for the internet connection! Thanks!
Do you mean this way?
However, I am still not receiving the internet connection (the internet led is flashing).
I received the activation message around 9am - should I wait some time for the internet to be activated?
Or it might be possible the cable is faulty and I need a technician?
  • August 30, 2022
Hello @Xemnad when I see the poor quality of the IS/RA-connection, you better ask for a technician.
  • August 30, 2022
Well...I don’t know whether it is faulty or not.
However, apparently, the modem is still not connected to the internet (I have also tried a reset).
When I try to look for the IP address on the KPN website, it says to me: “We kunnen uw modem niet bereiken. Controleer of uw modem aan staat en/of probeer het later opnieuw.”
RBxx
  • August 30, 2022
Hi @Xemnad , did you try both connections on the white box, not only the right hand side?
If that doesn't work either, better call KPN at 0800-0402 and ask for an technician.
  • August 30, 2022
RBxx
  • August 30, 2022
Good to hear @Xemnad that you succeeded with my help. Sometimes a solution can be so simple 😁
