Superwifi vs Experia wifi
  • feb 2, 2021 8:46 p.m. UTC
  • 0 reacties
  • 99 keer bekeken
Hello,
With the old Experia wifi i can get a speed of +-300mbps, with the new Super wifi only less then +-100mbps.
Both device i was testing with the same V12 box, and with the same network (cables also).
Both are working with Auto channels. (but this point is strange, because the setups says, currently used channel 100, but for manually i can choose only from 4 numbers, and the max is 48. The wifi analyzer advise to use channel 157.
Any body knows what can i change/modify to get the new Superwifi to work on a faster speed?
(i did turn the 2.4ghz to b+g+n and the 5ghz to a+n+ac)
