Using a second router after experia box
  • November 25, 2020
  • 318 keer bekeken
Hi,
I have a simple question on the configuration of my home network.
I have an experia box (used as modem and router) and a TV receiver. However, I find the function of the experia box limiting. So, I want to add my own router after experia box and move everything in the house under that router.
In that case, if I want to connect my TV receiver to my own router. Would it work? Is enabling IGMP snooping in the router enough to make it work? Or is it a no go?
Thanks a lot!
Best regards
Han
Admin: topic verplaatst naar juiste board
Welcome to the KPN Forum @yanhan! It is possible to use another router in combination with the Eperiabox. Which type works varies however. I would like to ask you to read through this forum topic on this subject and our page about using your own router. We do have the option to rent a Fritzbox from KPN. This option should be available, depending on your contract, in your MijnKPN. If you choose this option you get free access to our Tech Desk, which is a departement within KPN that supports home equipment like Smart Home products.
Bram van KPN
Forum|alt.badge.img+17
  • November 30, 2020
Bram van KPN
  • December 4, 2020
Since there has been no response I`m going to assume you have found a solution to the problem. If there are still questions about the original topic do feel free to reply here! :relaxed:
  • January 22, 2021
Hi Bram,
Sorry for the late reply.  Thanks a lot for the information. I carefully studied how the suggested configuration and the devices. Finally, due to limitations in the house, (mostly wiring limitations) I decided to keep the Experiabox as the main router.
Best regards
Han
