VPN does not work with my Box12 due to DNS settings?
  • jan 13, 2023 3:46 p.m. UTC
  • 67 keer bekeken
Hello, I am also having some problems with DNS while using KPN box 12 router. The issue I am connected to my companies VPN but DNS is not correctly set so I cannot see some websites as I supposed to see. IT responded it as an router issue. How can I solve this?
Admin: afgesplitst
  • jan 13, 2023 4:45 p.m. UTC
What is set as DNS server?
  • jan 13, 2023 4:52 p.m. UTC
How/where can I find it?
  • jan 13, 2023 4:59 p.m. UTC
Strange, you say you are having problems with the DNS but have not yet checked if the DNS is set correctly?
You can check which DNS server is used by checking the IP addresss of the configured DNS server via the CMD "ipconfig /all".
  • jan 13, 2023 5:15 p.m. UTC
192.168.2.254. I think you are asking this. IT of my company told me the problem so I just copied their definition :D
  • jan 13, 2023 5:17 p.m. UTC
Can you post a screenshot of the DNS part of the ipconfig /all command?
  • jan 13, 2023 5:25 p.m. UTC
