Windows 10 pc won't connect (DHCP)
  • July 13, 2021
  • 1 reactie
  • 70 keer bekeken
OK, so first of all the new cable modem is working fine. I can use wifi from other devices. Some other PCs can connect as well,
But a Windows 10 PC, that has always been connected to a DSL modem and working perfectly fine, does not let me surf when I connect the ethernet cable to Cable modem. I have tried POPO, release, renew command etc.
is it because DNS resolution gets messed up? (PC is on dhcp)
Admin: nieuw topic voor je vraag aangemaakt
1 reactie
  • July 13, 2021
Can you show ascreenshot of the IPv4 settings of the LAN network interface and/or the wifi interface depending on how you connect the PC to the network.
