Good morning, I paid for the invoice on May 19. And now I see that you have charged the invoice for the second time on 02-06-2022. I would like to clarify this
Bladzijde 1 / 1
Eerste factuur en een tweede factuur?
Hello
Sometimes, however, the payments are not for the same invoice. Even though it looks like it. If you want to know for certain, you can always give us a call at 0800 0402. Our department Collections can look into it for you.
Ik denk dat het gewoon 2 verschillende factoren zijn, en dat het probleem al lang opgelost is.
