4Gbps Not as expected
  • June 12, 2024
  • 42 reacties
  • 1033 keer bekeken
42 reacties
  • June 15, 2024
Just to clarify.  My computer is connected via 10Gbps to my switch and from there 2.5Gbps to the Fritzbox.  As you can see I pretty much reach full download speed but upload is 50% of what I should be getting.
getting a KPN engineer on site is impossible, they simply don’t want to do it.  As soon as Odido has 4Gbps in my area I’m moving.
  • June 15, 2024
That really is a shame an engineer is probably the solution. 0800-0403 is the only department who can make that happen.
  • June 15, 2024
@Ik_Combineer I was on the phone with them for 45mins culminating in the person on the phone saying “Sorry there is nothing we can do”.
which is why I’m switching to Odido as soon as I can.
customer service is very poor.
bnh
Forum|alt.badge.img+12
  • June 15, 2024
Call again, the need to send someone.
  • June 16, 2024
have you tried connecting your pc directly to the modem without the switch?
Does your pc has 10gbs network card?
Do you use minimum cat6 cable?
Do you have a strong pc 4gbs connection needs a fast pc?
  • June 16, 2024
https://ibb.co/wRNhy5C
this is my speedtest from oakla if i put the 10gbs switch between it i maximum have 1 gbs
without the switch i have full speed full 4fgbs
MR_CHIP
Forum|alt.badge.img+7
  • June 16, 2024
maybe moderator can plan a mechanic for you this is not the way it has to go
  • June 16, 2024
@BOSS1 Thanks for your response.  Yes, I have a 10Gbps card in my PC.  I tried connecting my PC directly to the 2.5Gbps Fritsbox port, and still got slow uploads. Have tried CAT6a and CAT7. Yes, my PC is a monster ;-).
@MR_CHIP I hope so. My “delivery manager” doesn’t seem to care and also after 45mins on the phone with them, they said there is nothing they can do.
I’m going to do a last set of tests tomorrow, using the Fritsbox (as this is all they will support) and then phone them again.
i truly suspect there is a rate limit configured somewhere on their network.  The reason I’m saying this is because I had a 1Gbps fiber, which has been upgraded to 4Gbps.  After the upgrade my download was also 1Gbps, but then an on-site engineer made a phone call and miraculously my download speed was fine (and my static IP changed) but my upload was still slow.
Sadly no.  I don't have acces to the KPN EEN (zakelijk)  database.  For support 0800 0403
Zakelijk is a different game and I can only help with the regular KPN clients.
MR_CHIP
  • June 17, 2024
Even not send them a email / ticket for request of assistance they wont help him apparantly he already called them
  • June 17, 2024
@Erwin van KPN I spent 45mins on the phone - we left the call when they said there is nothing they can do.  Today my speed is even worse. 2.5Gbps down, 600 UP. I also tried on the chat in the app, which also points me to the phone number.  All I want is for an engineer to come to my house, test the fiber with his/her own equipment.  If it reaches 3Gb up and down, then I’ll accept the fact that my equipment is crap. I’ll even pay for their time. But I need someone to come to my house and test.  I cannot spend another 45mins only for them to tell me they can’t help.  You’ll also see an order I placed with Ziggo.  Yes it is slower, put at least they deliver what they say they will.  If my KPN is not resolved this week, I am cancelling.
  • June 17, 2024
  • June 17, 2024
i used to have ziggo but im glad that i switched to kpn you pay 2 much for ziggo and your uplink stays 100mb, maybe the problem is really your modem and you must demand the kpn modem14 that should help you alot trust me i've been there at ziggo and i never want to go back to them i replaced all coax cable for cat6a cable only data for me now :) don’t make the mistake to go to ZIGGO don't do it brother, also try to do the kpn speedtest with chrome you will get must better results trust me
  • June 17, 2024
@BOSS1 he isn’t a consumer but a KPN EEN or also known as an business account. The box 14 doesn’t exists for business accounts.
  • July 10, 2024
Just to keep you all updated, without any changes, I now get 3 Gbps upload using my Dream Machine Max.
What is frustrating is that KPN obviously did something, but their message all the time was that they can’t help - well clearly they could.
  • July 10, 2024
im glad everything worked out brother what is you download btw?
  • August 3, 2024
I have a Unify Next gen gateway pro and same KPN 4GB with new OTN (nokia) and SFP+ UTP connected to OTN
Before the last UXG firmware I had to set smart queues to 0 and 0 MpBs that resulted in a higher upload ± 2.8 GB and down 2GB (so setting smart queues to 0 instead of a value but is wat enabled)
After the last UXG firmware I disabled smart queue now i’m getting
Now using firmware 4.0.6.16513
