Can I have temporary internet while fibre is being installed?
  • September 10, 2021
  • 1 reactie
  • 85 keer bekeken
I have a bit of an issue in terms of internet access at the moment. My fibre will only be activated on 2 November. I dont have access to copper at my house and no Ziggo to use in the interim.
Does KPN offer 4g internet that I can use while I wait for my fibre package? I need to work from home and stream until then.
Thank you.
@WesP Welcome to our forum.
At this moment we don't offer a 4G connection that you can use till the activation.
But I would to check if there is anything I can do for you.
Could you fill in your forum profile and let me know when you did? Then I can check the situation and see if there is anything I can do for you! :)
1 reactie
Rutger van KPN
  • September 13, 2021
