Do i need a special connector/cable to connect my KPN modem?
  • October 31, 2023
  • 1 reactie
  • 186 keer bekeken
Hello,
I moved recently to Amsterdam Noord and I have moved my KPN connection to the new address.
I have the the Experia V10 modem that has a DSL connector.
The house has a coaxial connection from ziggo and a 4 pin connector supposedly for KPN.
Would I need a special connector/cable to start using the internet? Could you order it for me?
Regards,
Yeraldin
Beste antwoord door Anonymous
Hello @Yeral
That called a “varkenssnuit” aansluiting, you will need a 4 pin plug like this for it:
You will also need a telephone cable with RJ11 connectors to connect the 4 pin plug to the grey DSL port of the modem.
If you do not have them, you can call KPN customer service 0800-0402 (Mon to Fri 8:00 AM - 6:00 PM and Sat 8:00 AM - 5:00 PM) and ask for them to be sent to you.
A KPN moderator on the forum can also send them to you but it can take up to 5 days before they respond in this topic, so calling the KPN customer service is the fastest way to get them.
1 reactie
  • November 1, 2023
Hello @Yeral
