When you are lucky it might propose to send two Experia WiFi's for free.
When you only have 70Mbps downstream through a wired computer then that is not as it should be. Was the computer connected directly to the V8?
yes, the computer connected with V8 directly.
only upload almost 90 Mb
Download 44~70 Mb
download also should be almost 90Mb thati expected
what i have to do? ( KPN contracted for 200Mb)
Thanks
My internet contract Hussel Internet 200 Mbit/s
Download 200 Mbit / s Upload 200 Mbit / s
Could you test the speed with another network cable?
I Tested 3 other network cable about only 1 meter.
CAT.5e
Could you please test the speed with another cable.
3 different lan cable result was all the same. no improved at all.
I hope that an employee of KPN will respond soon as you should always measure at least 200Mbps on a wired computer with https://kpn-itns.speedtestcustom.com.
Do i have to call KPN service with 50 euro for the technicus reservation to visit my house?
You can call customer service at 0800-0402 or just wait for a KPN moderator to respond.
I decide to move to other Internet provider.
I think that is very strange the policy “no change process old V8” that was used from 2016.
I think for some long term used customer need to have the benefit to be replaced new V10.
I hope to see you again with KPN for next time.
Good afternoon @Billy Yang, sorry for my late response. I'm afraid that we can't change the V8 for a new modem unless we conclude that it's actually broken as @wjb mentioned. I'd like to take a look at your connection to see if I can see any problems with it. Could you fill in your profile and let me know when you did?
De Kennisbank
Bestand scannen voor virussen
