Fibre speed is only 90Mbps (up and down), I pay for 1Gbps
  • January 16, 2024
  • 8 reacties
  • 155 keer bekeken
Is there a reason why I am losing 90% of the service I am paying for?
I recently noticed serious lag working from home… I performed a test as above.
I can understand the odd 200Mbps discrepancy… But not 900Mbps discrepancy.
Both on WIFI and LAN are the same.
Same on MAC BOOK and same on Windows10 Laptop
Your cable between the (O)NT and your modem is probably bad. Could you try another cable?
an faulty lan cable falls back around 93/94 mb.
It is the cable yes - between the router and the switch… probably damaged somehow since it is a bit exposed near the skirting board and doors
Thanks for your help.  Im a little embarrassed of my poor diagnostic skills
Don't be, it happens to the best of us. Glad to hear/read that it's fixed.
8 reacties
  • January 16, 2024
It is the same speed as my mobile phone hotspot 5g:
  • January 16, 2024
Forum|alt.badge.img+28
  • January 17, 2024
Hi @KristonR
My instict is also that the issue is the cable, like Ik_Combineer said. Did you try anothe cable, cat6?
  • January 17, 2024
Thanks.. I will check… sorry for my ‘JUMPY’ subject title.  😐
When I connect to actual WIFI I am getting 300Mbps - Turns out I was still on wired when I performed the comparison test.
I have a NETGEAR SWITCH - could be that too
  • January 17, 2024
That shouldn't be the issue. If you want to know for sure, connect your laptop withtout the switch directly to the modem, preferably with another (cat6) cable.
  • January 17, 2024
Or an cat5e cable. That is also good for 1Gb lines.
  • January 18, 2024
  • January 18, 2024
