Fritz repeater 310 does not work with Experia V10A router
  • February 3, 2019
  • 209 keer bekeken
Recently we received an Experia V10A router. It seems that my Fritz repeater 310 is not working with this router. It worked with the previous ones.
Can you please advise what to do?
Hi @sdha . How do you connect your repeater to the experiabox? My advice would be to always use a network cable.
If you connect a repeater wirelessly it won't be very effective. Also I have no knowledge of the Frits repeater so I wouldn't be able to help you with that, sadly :'(
2 reacties
  • February 4, 2019
I haven't heard from you and I'm hoping the problem is fixed! If not, please read my suggestions and otherwise perhaps contact XS4all ( they have fritzbox equipment or contact Fritzbox support )
