FTU Box - only power and ethernet lighted but glass not lighted
  • September 12, 2019
  • 95 keer bekeken
Please help. Troubleshoot done for both box and modem
Beste antwoord door Susan_
Hi @JenJanice, welcome to our Forum!
I already checked on your zipp code you added in your profile, and I see that a technician has been scheduled for this afternoon between 15.00-17.00. So I assume it will be resolved this afternoon 😉
Have you also removed power from the NTU?
Yes I did for both. Also reset the modem.
Then I hope that an employee of KPN will respond soon as this seems to be either a faulty NTU or that the fiber is not connected anymore in the PoP (Point of Presence).
Susan_
  • September 13, 2019
Susan_
  • September 15, 2019
@JenJanice, did the technician repair the connection with internet? So is your problem solved?
