Help with correct location for the modem
  • July 12, 2024
  • 112 keer bekeken
Hi all,
I would like to get answers for the following question.
I live in a 40m2 apartment, and I recently switched to KPN from Ziggo.
The fiber termination is in the meter cabinet which is located outside my apartment in one of the corner. There is also a ethernet connection between the living room and the meter cabinet.
When I keep my modem in the meter cabinet I see that I get a decent signal ( -60dm) in the furtherest part in my apartment, and the speed is significantly low in WiFi when I measure speed close to modem Vs inside my house. ( Almost 50% slower).
I tried to use the ethernet connection to connect the modem in my living room via existing ethernet connection I am guessing the length is around 10 meters approx . But with this the speed is significantly lower .
I suspect that the speed is lower because of the ethernet connection between the modem and the black unit on the termination is not using the red cable and/ or the distance..
Is it possible for me to solve this issue related to speed if this ethernet connection of 10 meters is rewired with the red cable ? Or is there not going to be an improvement in the speed by doing this?
Hi @Abhi8741 .  If there is a quality cat5a cable (or higher) between the Fiber box and our modem, it could potentially be a pretty long cable before you really start losing speed.
10 meter shouldn't be an issue.
Forum|alt.badge.img+5
  • July 16, 2024
Are your sure its fiber what you have ?   can you post a picture of what you have in the meterkast ?
  • July 16, 2024
‘officially’ we advise a short cat5a (or higher) cable.  But there should  be no significant signal loss if you use a longer cable (10-15 meter)  as long as its a quality cable, minimum cat5a
