Het laden van foto's met mobiele telefoons is traag op wifi
  • December 9, 2024
  • 60 keer bekeken
Hi,
Writing in English since it’s easier.
I had a setup at home that worked well, it’s been 3 days since I moved to KPN
loading images such as what’s app gifs or picture in funda are slow but only with telephones
not with laptop connected to wifi.
This was tested using two different telephones, both work when not connected to wifi.
wifi setup is with my own devices and KPN router just issue IP addresses using DHCP
Has anyone experienced that?
Thanks
  • December 9, 2024
it seems that the issue, is that some devices were getting both dynamic ip address and a static one
does the router knows not to assign an IP address to a MAC which we reserved an IP?
  • December 9, 2024
that did not solve it
Jan van KPN
  • December 11, 2024
Hello ​@orgerson , thanks for your message and welcome to our Community :)
A couple of days have past since your post, has anything changed? It's certainly strange that you only experience this problem on a phone and not with a laptop. Have you already tried to run the KPN Wifi manager? This is an online tool that helps you improving the wifi.
  • December 12, 2024
I think the DNS servers are slow
I changed to google DNS servers I think that solved the issue
I will check the wifi manager later on.
  • December 16, 2024
Issue was solved by turning off IPv6 in the device
The device does not automatically revokes a previously given Ip address when you try to reserve it for static, it was unrelated
Jan van KPN
  • December 16, 2024
Thanks for sharing this with us ​@orgerson :)
