How check wiffi pasword
Bladzijde 1 / 1
Hi @Lysy It depends. Could you explain a little more? Have you changed the wifi password from your own network, or do you still use the original password? You can find that on the sticker on the Experia Box.
Hello @Lysy I was just wondering, have you succeeded in checking your password? Let me know if I can help you with something.
