Linux machine connects to Wifi but not Internet
  • jan 4, 2024 12:44 p.m. UTC
  • 156 keer bekeken
I recently switched from T-Mobile / Odido, after the switch, My Ubuntu machine would not connect to internet, IP setting is DHCP automatic.
Please help
Beste antwoord door Anonymous
Connecting it with a netwerk cable is not possible?
Can you force the Wifi on 2.4GHz in Ubuntu, else make an Extra Wifi network on the modem for only 2.4GHz and connect it with that SSID, does it work then?
  • jan 4, 2024 3:43 p.m. UTC
Hello @Lone_wolf
What KPN modem do you have and if it's a Box 12, which firmware version does it have?
Is the modem the only Wifi AP or do you have extra Wifi AP's like SuperWifi (if so the white or the black ones)?
Which IP address does the Ubunu machine receive, does it also get a Gateway address and a DNS server IP address?
Does it work when using a netwerk cable?
  • jan 4, 2024 3:57 p.m. UTC
Hello @GeSp
My modem is KPN Box 14 (as only Wifi AP), No Internet, when tried with wired network,
It doesnot receive any IP, even though set as DHCP, Modem apparatus list shows No IP for this device and displays static,
Same machine picked up proper IP an internet connection through my Mobile hotspot and previous router from Odido
I even tried reinstalling the ubuntu OS from scratch, I noticed the even during the install I couldn't connect to KPN Wifi for some reasons.
  • jan 4, 2024 4:10 p.m. UTC
