Log in Experiabox
  • December 12, 2019
  • 127 keer bekeken
Zonder grapjes, dit kan via 192.168.2.254 eerste keer zonder wachtwoord en als een monteur hem heeft ingesteld is het "kpn", "admin", of "1234".
I just got the service yesterday. None of these worked for me ..! Is the technician allowed to change it to another password.
*Admin: afgesplitst en eigen topic voor je vraag aangemaakt
Beste antwoord door WaleedAlhumaikani
Hi @WaleedAlhumaikani, when logging in for the first time, the technician (or anybody else for that matter) is forced to change the password. However, he/she should have told you the new password.
Which Experia Box do you have?
Well .. Obviously the device I got is different (Experia Box v10A). It has a white sticker in the back with access credentials. Now I’m able to access it after I executed factory reset and used the passwords in the back.
Thank you @RBxx for your response :)
RBxx
  • December 12, 2019
RBxx
  • December 12, 2019
Yes, that's why I asked which one.
The v10A is the only one with the credentials on the back. The other (older) ones have an empty password after a factory reset and the obligation to change it when logging in for the first time.
Paul van KPN
Forum|alt.badge.img+26
  • Oud-Moderator
  • December 14, 2019
Hello @WaleedAlhumaikani, welcome! I'm glad eventhing worked out. Thanks @RBxx
