I recently subscribed to 4gbp, I have a v14 box that supports 10gbp I also have a 10gbp Asus pcie card. But when I do speed test I only get 1gbp max speed
Did you makte the ONT powerless for two minutes ? Also, what says the internal (you need to login on the box v14) speedtest of the modem ?Â
Am getting 4077 download and only 844 upload and I actually need more upload than download since I host my own website.
Did you do this test with the internal modem Speedtest function?
No I used Ookla how do I do thatÂ
I have found it am getting 4098/2996
Â
That’s already better! So the issue should be internal with the uploads. Can you download the Ookla app in your pc and test again. Try to use the KPN test server Amstelveen. I’m always have good results on that server.
Hi ​
