I cannot access my router V10A as the admin password in the label is not working. Please advise how to reset it or change it.
@Soter
Push a paperclip or something like that in the reset hole till the power light will blink red.
The modem will start up !! Please give it some time and don't interupt the procedure till everything is okay. After that you can log in with admin without a password.
Addition to this message. After the reset, log in with the admin password on the label at the back.
example
Hello @Soter, did those instructions posted above the trick to acces the webinterface?Â
