Sagemcom F5359 parental control filter urls. How to?
  • February 11, 2022
  • 463 keer bekeken
Hello, I have Sagemcom F5359 modem or kpn box 12, and I need to setup parental control to limit access to some specific sites by filtering urls, but looking at the modem settings it is only possible to completely disable internet on specific devices. Unfortunately that option is useless for me because kids still need access to internet, for example to do homework, etc. I also could do this quite easily with 6 years old modem from Vodafone.
So how it is possible to do with KPN?
Beste antwoord door RBxx
Hi @rumax
Unfortunately it's not possible to filter url's on this latest KPN modem.
Parental control only controls internet access per device on set times.
Some earlier modems provided ECO mode, that switched off WiFi thereby blocking all devices.
2 reacties
RBxx
  • February 11, 2022
Hi @rumax
Hi @rumax, welcome to our forum!
I see that @RBxx already answered your question. Parental control in the KPN Box 12 doesn't have other options right now. I'm not sure if the options will change in the future. You can follow our KPN Box 12 update topic for the latest news about updates. It is in Dutch tho, maybe you could use the help of Google Translate if you'd like to follow it. I hope you find another solution for the settings you'd like to make.
