Unstable Internet Connection since I switched to KPN from Odido
  • December 11, 2024
  • 1 reactie
  • 65 keer bekeken
Hi,
We have switched to Kpn Home Internet from Odido and we are having too much internet connection issues. We have a router on the entrance floor and we have a repeater on 2nd floor which is connected to KPN Modem. We have tried changing the cable between KPN modem and the 2nd floor repeater, which didnt help at all.
The only time that we didnt get issues happened the day I made a thuisnetwork reset, but again the issues have continued today. Okla Test shows high numbers but we didnt have these unstabilities before with Odido.
In the forum, I read that 70 euros is asked to send a guy to check the modem, but I dont think I should pay anything at all bc it is not customer's fault, but rather KPN's problem.
I am sorry to read that your switch from Odido to KPN has been less pleasant than you expected, ​@AGunsu. I would advise you to give this servicetool a try: Last van internet- of wifi-problemen?. With this, you should be able to solve most of the internet issues. If this doesn't help, it's probably best to give us a call. You can make a phonecall appointment here: belafspraak. One of my colleagues will then give you a call at a time of your choosing.
1 reactie
Denise van KPN
  • December 13, 2024
