What's the best internet solution at home for me? Don't have a provider at home at this moment. Working with unlimited data
  • January 9, 2024
  • 116 keer bekeken
Good morning.
I live in a rural area of Netherlands , so in this case no provider can give me internet at home at the moment , although i have applied for glasvezels through KPN, which my area is scheduled but this will be ready (if) in 2025.
So for now , i have bought a sim from KPN and i’m using it for internet at home but the thing is that although unlimited , at 10GB i have to replenish with 2GB each and every time which is not very convinient when you stream music , series, games etc at home .
What i wanted to ask , is there any solution about this problem? Because it is a problem , when you are using definetely more than 10GB per day .
Thank you very much for your time.
  • January 9, 2024
Don't you have a DSL connection for kpn?
And no coax (cable) connexion f.i. for Ziggo?
The unlimited subscription is not intended for use in a mifi router. And not intended for home use. Which is often about 15 to 30 GB per day including watching tv and streaming.
The only provider who has a 4G subscription of home use is Odido. Only there is also a limitation of 150 GB per month. Which is about GB per day. KPN has 10.
See http://odido.nl/4g-voor-thuis .
If no landline (DSL, FttH or Coax) is possible above are the only options.
  • January 9, 2024
At the moment , there is no provider that can cover the area and odido does not have a good coverage here , which KPN has and 150GB per month so 5GB/day is nothing so even that is of no use .
I know it's not intended for this kind of use but what can you do if you can't have regular internet , not even dsl.
In any case then , I will continue doing what I'm doing until and hopefully glasvezel will be installed in my area , therefore in my home too , it's only a year 😅
  • January 9, 2024
There is no solution for via 4G. It's not meant for use instead of fixed internet.
Use more efficiënt is the only solution.
MR_CHIP
Forum|alt.badge.img+7
  • January 9, 2024
there is also a 4th option
starlink
Bart van KPN
  • January 10, 2024
You can check your adress at KPN Netwerk to see if there are plans for installing fiber on your adress.
Forum|alt.badge.img+5
  • January 10, 2024
Are you sure DSL is not posiable, have you checked this
https://www.kpn.com/shop/pakket-zelf-samenstellen?icid=quicktile3
