Al een paar maanden lang valt onze wifi elke dag een aantal keer weg. De log toont dit:
Weet iemand een oplossing? Al vele apparaten gecheckt, maar het probleem is nog niet opgelost. Ik las online wel dat er wat mis is met de Box V12. Verder heb ik geen goede oplossing.
02.01.2022 18:33:34 | Debug | DNS | DNS name resolution failure (lb._dns-sd._udp.kpn) |
02.01.2022 18:33:13 | Debug | DNS | DNS name resolution failure (lb._dns-sd._udp.kpn) |
02.01.2022 18:32:53 | Debug | DNS | DNS name resolution failure (lb._dns-sd._udp.kpn) |
02.01.2022 18:32:30 | Debug | DNS | DNS name resolution failure (lb._dns-sd._udp.kpn) |
02.01.2022 18:32:13 | Debug | DNS | DNS name resolution failure (lb._dns-sd._udp.kpn) |
02.01.2022 18:31:44 | Debug | DNS | DNS name resolution failure (lb._dns-sd._udp.kpn) |
02.01.2022 18:31:29 | Debug | DNS | DNS name resolution failure (lb._dns-sd._udp.kpn) |
02.01.2022 18:31:12 | Debug | DNS | DNS name resolution failure (lb._dns-sd._udp.kpn) |
02.01.2022 18:31:08 | Debug | DNS | DNS name resolution failure (https://app-measurement.com/sdk-exp) |
02.01.2022 18:31:08 | Debug | DNS | DNS name resolution failure (lb._dns-sd._udp.kpn) |
02.01.2022 18:31:04 | Debug | DNS | DNS name resolution failure (lb._dns-sd._udp.kpn) |
02.01.2022 18:30:51 | Debug | DNS | DNS name resolution failure (lb._dns-sd._udp.kpn) |
02.01.2022 18:30:30 | Debug | DNS | DNS name resolution failure (lb._dns-sd._udp.kpn) |
02.01.2022 18:30:09 | Debug | DNS | DNS name resolution failure (lb._dns-sd._udp.kpn) |
02.01.2022 18:29:58 | Debug | DNS | DNS name resolution failure (lb._dns-sd._udp.kpn) |
02.01.2022 18:29:54 | Info | SYS | Modem login was successful |
02.01.2022 18:29:42 | Debug | DNS | DNS name resolution failure (lb._dns-sd._udp.kpn) |
02.01.2022 18:29:22 | Info | WIFI | Channel: (100/52) Channel Hopping initiated/Manually initiated |
02.01.2022 18:29:18 | Debug | DNS | DNS name resolution failure (lb._dns-sd._udp.kpn) |
02.01.2022 18:29:08 | Debug | DNS | DNS name resolution failure (lb._dns-sd._udp.kpn) |
02.01.2022 18:28:39 | Debug | DNS | DNS name resolution failure (lb._dns-sd._udp.kpn) |
02.01.2022 18:28:28 | Debug | DNS | DNS name resolution failure (lb._dns-sd._udp.kpn) |
02.01.2022 18:28:20 | Debug | DNS | DNS name resolution failure (lb._dns-sd._udp.kpn) |
02.01.2022 18:28:17 | Info | SYS | TR-069 connectivity to (hengelo0.cust.kpn.net) has been closed |
02.01.2022 18:28:17 | Info | SYS | TR-069 connectivity to (hengelo0.cust.kpn.net) has been initiated |
02.01.2022 18:28:13 | Info | SYS | TR-069 connectivity to (hengelo0.cust.kpn.net) has been closed |
02.01.2022 18:28:12 | Info | SYS | TR-069 connectivity to (hengelo0.cust.kpn.net) has been initiated |
01.01.2013 01:00:34 | Info | PPPOE | PPPoE connection successfully established with user credentials. |
01.01.2013 01:00:33 | Info | PPPOE | PPPoE connection successfully established with user credentials. |
01.01.2013 01:00:33 | Info | DHCPC | The WAN DHCP client IP address 10.207.68.34 |
01.01.2013 01:00:29 | Info | UPNP | UPnP functionality has been activated |
01.01.2013 01:00:29 | Info | DHCPC | WAN DHCP client (1) started |
01.01.2013 01:00:27 | Info | WETH | WAN Ethernet connectivity has been established |
01.01.2013 01:00:27 | Info | LETH | An Ethernet port is now connected (4/1000/FULL) |
01.01.2013 01:00:27 | Info | LETH | An Ethernet port is now connected (3/1000/FULL) |
01.01.2013 01:00:27 | Info | LETH | An Ethernet port is now connected (2/1000/FULL) |
01.01.2013 01:00:27 | Info | LETH | An Ethernet port is now connected (1/100/FULL) |
01.01.2013 01:00:18 | Debug | DNS | DNS name resolution is now active |
01.01.2013 01:00:18 | Info | DHCPS | The LAN DHCP Server is active |
01.01.2013 01:00:18 | Info | WIFI | WLAN has been deactivated (.) (band : 5GHz). |
01.01.2013 01:00:18 | Info | WIFI | WLAN has been deactivated (.) (band : 2.4GHz). |
01.01.2013 01:00:18 | Info | WIFI | WLAN has been deactivated (KPN Fon) (band : 2.4GHz). |
01.01.2013 01:00:18 | Info | WIFI | WLAN has been deactivated (KPN55A9A6_guest) (band : 5GHz). |
01.01.2013 01:00:18 | Info | WIFI | WLAN has been activated (Gasten) (band : 2.4GHz). |
01.01.2013 01:00:18 | Info | WIFI | WLAN has been activated (Amsterdam) (band : 5GHz). |
01.01.2013 01:00:18 | Info | WIFI | WLAN has been activated (Amsterdam) (band : 2.4GHz). |
01.01.2013 01:00:17 | Info | WIFI | Channel: (0/100) Channel Hopping initiated/Manually initiated |
01.01.2013 01:00:17 | Info | WIFI | Channel: (0/1) Channel Hopping initiated/Manually initiated |
01.01.2013 01:00:14 | Info | SYS | The Modem has successfully powered up |
01.01.2013 01:00:14 | Info | SYS | The Modem underwent a warm reset |
