AL geruime tijd vraagt KPN veilig om de paar minuten om opnieuw te starten.
In het begin deed ik dat maar om dit elke 10 minuten te doen is te gek.
Als ik in de log kijk zie ik :
2021-07-31 23:26:09.475 [1230.177c]  I: ***  LOGGING STARTED  *** (UTC+2:00, session: 0x0)
2021-07-31 23:26:45.349 41230.177c]  I: Checking for updates from guts2.sp.f-secure.com
2021-07-31 23:26:45.364 31230.177c]  I: Update check failed, error=210 (unable to resolve host)
2021-07-31 23:26:50.395 .1230.177c]  I: Checking for updates from guts2.sp.f-secure.com
2021-07-31 23:26:50.395 01230.177c]  I: Update check failed, error=210 (unable to resolve host)
2021-07-31 23:26:59.414 51230.177c]  I: Checking for updates from guts2.sp.f-secure.com
2021-07-31 23:26:59.414 :1230.177c]  I: Update check failed, error=210 (unable to resolve host)
2021-07-31 23:27:09.439 71230.177c]  I: Checking for updates from guts2.sp.f-secure.com
2021-07-31 23:27:09.439 21230.177c]  I: Update check failed, error=210 (unable to resolve host)
2021-07-31 23:27:34.464 :1230.177c]  I: Checking for updates from guts2.sp.f-secure.com
2021-07-31 23:35:29.865 31230.177c]  I: Checking for updates from guts2.sp.f-secure.com
2021-07-31 23:35:42.294 21230.177c]  I: Checking for updates from guts2.sp.f-secure.com
2021-07-31 23:39:31.169 1230.177c]  I: Checking for updates from guts2.sp.f-secure.com
2021-07-31 23:42:24.476 11230.177c]  I: Checking for updates from guts2.sp.f-secure.com
2021-07-31 23:42:25.835 31230.177c]  I: Checking for updates from guts2.sp.f-secure.com
2021-07-31 23:42:27.242 -1230.177c]  I: Checking for updates from guts2.sp.f-secure.com
2021-07-31 23:42:30.490 71230.177c]  I: Checking for updates from guts2.sp.f-secure.com
2021-07-31 23:42:31.389 01230.177c]  I: Checking for updates from guts2.sp.f-secure.com
2021-07-31 23:42:32.248 -1230.177c]  I: Checking for updates from guts2.sp.f-secure.com
2021-07-31 23:42:32.920 11230.177c]  I: Checking for updates from guts2.sp.f-secure.com
2021-07-31 23:42:33.670 21230.177c]  I: Checking for updates from guts2.sp.f-secure.com
2021-07-31 23:42:34.327 01230.177c]  I: Checking for updates from guts2.sp.f-secure.com
2021-07-31 23:50:27.473 21230.177c]  I: Checking for updates from guts2.sp.f-secure.com
Hallo @Verst01 ,
Ik zou eerst KPN Veilig eens helemaal verwijderen. En daarna weer terug erop zetten.
Hoe verwijder ik KPN Veilig van mijn laptop of PC?
  1. Klik links onder op het hWindows] icoon
  2. Navigeer naar KPN Veilig
  3. Klik op iInstallatie ongedaan maken]
  4. Klik op lKPN Veilig]
  5. Klik op KVerwijderen/wijzigen]
  6. Selecteer eAlle applicaties verwijderen]
  7. Klik op iVolgende] KPN Veilig wordt van je PC verwijderd
  8. Klik op lSluiten] KPN Veilig is van de PC verwijderd
Hoi @Verst01, welkom op het forum. Elke 10 minuten opnieuw opstarten is wel heel veel inderdaad, dat is niet de bedoeling! Ik ben net als Noordzee benieuwd hoe het gaat als je KPN Veilig verwijderd en daarna opnieuw installeert. Blijft deze melding dan ook komen?
We hebben geen reactie meer van je gezien @Verst01, ik hoop dat dat betekent dat de tip van Noordzee de oplossing was. Als dat niet zo was horen we het graag van je.
Noordzee,
Bedankt, werkt weer
