Hi all, I would like to advise you on the connection of the 4K UHD TV receiver I received for the TV. The problem is that there is no Ethernet socket where the TV is. There is a normal input to the TV. Is it possible to reciver for example via WIFI with a router and directly to the TV, without connecting the 4K UHD TV receiver to the input in the "wall" ?
Welcome to the KPN forum
The first option you could choose is the SuperWifi. It has a port for an internet cable. You can use this port to connect to the tv-box. It will also improve your wifi. If you need this in your house to have proper wifi coverage you may be eligible for a discount if you follow the steps on our Wifi Manager.Â
The second option is a DVS. It is designed to transfer internet signal over powerlines. It does have the downside that other appliances may disrupt this signal. Things like certain types of lights or chargers.Â
The caviat for both of these is that it does not fall under warranty. The equipment itself does. You have the standard consumer protections and return policies. But we can't guarantee that your tv signal will always work. If it does show problems with the signal you may need to provide a wired connection after all. If you can't do this youself we do have engineers who you can help with this. Terms and conditions are on our page about engineers. Â
Hello ,
Thank you very much for your advice, I have found a solution but it will require pushing about 15 metres of Ethernet cable through the narrow pipe that runs from where the router is to the TV. I'm not sure I can manage this, I understand that I can count on your support and help from fellow service people? Greetings Jakub
Will you let me know here when you succeeded? Or if there are more questions?
