Greetings,
apologies I cannot write Dutch. I use translator to read messages.
I am recently begin moved from Telfort to KPN.
I have glass fiber connection and I used to have Mikrotik for internet and bridged IPTV.
Since the move, KPN uses routed IPTV.
I have red a lot of articles also in netwrkje siteā¦
Still unable to get the both working.
I think (but not sure) that the bigger issue is that the configuration I found refers to a pppoe and needs credentials to add to the connection.
That I dont have. I dont use a DSL connection.
this link in KPN Forum, shows a configuration (similar to the one I saw in Netwerkje).
https://forum.kpn.com/thuisnetwerk-72/configuratie-mikrotik-rb4011-494258
but again, it refers to pppoe: āadd add-default-route=yes allow=pap disabled=no interface=vlan1.6 \
keepalive-timeout=20 max-mru=1500 max-mtu=1500 name=pppoe-client user=\
************@direct-adsl
ā
Can someone help me to find a configuration that works using fiber optic?
As we speak, I do have internet and a basic TV as I use the Telfort configuration with a bridged IPTVā¦ but the configuration is incorrect; internet vlan is wrong (even if it works) and IPTV is very limited.
No credential for internet ar used at the moment, only DHCP clinet.
I hope someone can help me out.
Kind regards
