First of all I would like to apologize you for the post written into English due to my Dutch language problem.
Respectfully, my KPN remote control is not compatible with my TV, OK. ODL32642H-DB, I carried out all the instructions found in KPN website, following link:
https://www.kpn.com/televisie/installeren/afstandsbediening/instellen.htm
When I insert in Merknaam televisie option the name of the TV, OK., it gives me the code of 463 doing all the instructions, and then, for changing the volume and tuning on/off the TV functions I must use the TV’s own remote control and for the other functions like changing channels, teletext...I must use the kpn tv-ontvanger’s remote control, and when I insert the name of the TV model, ODL32642H-DB. in Modelnummer televisie option it tells,” Er zijn helaas geen codes gevonden voor het opgegeven modelnummer”.
Also I proved the option of the “ Mijn merk staat er niet tussen’ following the snelcode ‘20’, I face the same problem as told above in which some options work with kpn’s remote control and some other work with the TV’s own remote control, please how I am able to fix the above problem using only the kpn remote control, it is to explain that my kpn remote control is Versie C3 (meegeleverd tot november 2014), thanking you.
HI!
If I understand you correctly, you tried the following codes, 463 and 20. If I search for codes that are compatible with your tv, I also find the following three codes: 001 366 402. Do you mind giving those codes a try? I hope one of those codes is the solution to the remote-TV problem, haha!
Please let me know if it still doesn't work. If that's the case I'll find you an other solution. This might be a ‘creative’ one.
HI!
Thanking for your respond, I proved the codes which you had given me(001, 366, 402), but, they did not help, and the problem still exists, as told above, some functions work with kpn remote control and some other functions with the TV’s own remote control.
If I know your answer, I'm going to ask our logistics department if they can send you our ‘older’ type of remote-control. I can't give you any guarantees, but I will try. BTW It won't be a peace of history that I will send you, it's just a different design.
As I told in above posts, also I have to use two remote, one the TV’s own remote and the second is the kpn remote, as I told before, some functions work with the kpn remote and some others work with the TV’s own remote, the version of my kpn is C3 (the old one, I think); “ Versie C3 (meegeleverd tot november 2014) ", thanking you.
Thanking you, I updated my profile giving the information that you had asked me, respectfully I fear that if I receive an older kpn remote than this one that at present I have, I will face more problem, thanking you again.
thank you very much for your help.
Thanking you, today I received the mentioned above new remote control; I installed according to the instructions (the code 366 was better, for the OK. TV), but the problem still exists, in this sense that some functions work with the KPN remote and some other functions work with the TV’s own remote, I fear that the KPN remote basically is not compatible with the OK. TVs and I have to go ahead using two remotes, however it is good to have a new remote in order not to face further problems as result of an old remote later, please this is my question whether I must send back my old remote to KPN? if yes, please give me the address where I must send it back, I would like to thank you for your valuable efforts to try to help me.
KPN Serviceretouren
Antwoordnummer 10119
2400VB Alphen a/d Rijn
If there's something else I could help you with, please let me know! You're more than welcome on our Forum!
