Remote control is not compatible with my LG TV
  • February 20, 2022
  • 1 reactie
  • 68 keer bekeken
Remote controller is not compatible with my Lg TV. I just had new box and controller because i moved the house. Older version remote controller was working perfect.
P.S The code also doesn’t make it work.
Thanks
Hi @Bircan, welcome to our forum. Which new tv-receiver did you get? It sounds like your remote is different from before. Have you followed the steps on this page: Afstandsbediening afstemmen of koppelen?
If it's a different remote, it's possible you need to use a different code too.
1 reactie
  • February 23, 2022
