Calls over Wifi not working anymore since 3 days
  • April 21, 2021
  • 18 reacties
  • 176 keer bekeken
hi there,
We have 2 Samsung s8 unlocked working pretty well... 3 days ago something strange happened, voice over wifi stopped working - we can still get ovice over LTE but not voice over wifi with the little phone icon.
I have tried every possible setting to no avail, restarted, airplane mode, toggle on and off both from Connections > Mobile Networks and the other one under Call > 3 dots > Settings > Wifi Calling and Wifi Preferred. nothing happens anymore.
also tried:
network reset on my phone
cleaned cache from boot menu
cleaned sim card plus checked all settings...
also tested with another wifi at my work and same story.
We didn't touch the software either. All it happened was a change in our wireless setup at home with new routers or something my landlord manages, but still does not justify why at my work doesn't work anymore as well.
Is anybody experiencing the same thing?
thanks
Gabrio
Hi @gabrio81, welcome.
Voice over wifi doesn't work anymore. :( You have tried a lot but you couldn't fix it. I think I know what the problem is. Is has to do with the new router, from a new internet service provider I guess? I think your IP adress isn't registered right in our system. Can you please fill in your IP adress in your profile under Persoonlijke opmerkingen (Privé). Will you let me know when you did?
18 reacties
Bart van KPN
  • April 22, 2021
  • April 22, 2021
Voice over wifi doesn't work anymore. You have tried a lot but you couldn't fix it. I think I know what the problem is. Is has to do with the new router, from a new internet service provider I guess? I think your IP adress isn't registered right in our system. Can you please fill in your IP adress in your profile under Persoonlijke opmerkingen (Privé). Will you let me know when you did?😞
thank you Bart, well the landlord said they "did" something new, which is not clear, indeed it could be that, so an IP not registered, I have filled that info in the profile as you asked me. or a port to open perhaps (which one?).
please let me know next steps, thank you
Bart van KPN
  • April 23, 2021
Thanks. I asked my colleague. Will be continued.
Bart van KPN
  • April 23, 2021
I got conformation, your IP adress is now registered in our database. You can call over wifi again.
  • April 23, 2021
WOW awesome service, i just checked and indeed it works, thanks a lot!
great work!
Gabrio
Bart van KPN
  • April 26, 2021
You're welcome!
  • April 29, 2021
hi Bart, i sent you a new PM, if you can add also my office IP…. cheers
Bart van KPN
  • April 29, 2021
I notified my colleague. I will come back to you.
Bart van KPN
  • May 2, 2021
Also that IP is now registered. :)
  • July 20, 2021
Hi, i sent a request for a new IP. Thank you
Bart van KPN
  • July 21, 2021
That one is not possible. It's not located in the Netherlands. So you won't connect to our network.
  • July 21, 2021
Ahh i thought you can still use voip on the wifi network i am connected here too :(
Would be cool if it works abroad since network can be also poor abroad, etc not only NL
Bart van KPN
  • July 21, 2021
I understand, but abroad you’are not connected to our Mobile Netwerk. And yes, it can be poor abroad, but that's not something we can fix. :(
  • September 4, 2021
  • May 22, 2023
Hi, i sent my IP address to you from PM.
can you please add it also?
thanks
Bart van KPN
  • May 23, 2023
@KKtheITGuy will you also update your profile with at least your mobile number. Will you know when you did? I will look into it.
  • May 23, 2023
@Bart_Z done,thank you :)
Bart van KPN
  • May 24, 2023
I notified my collegues of the Back Office to look into it. I Think within 5 working it will work.
