Change mobile phone subscription before end of contract
  • October 21, 2022
  • 260 keer bekeken
Hello. Is it possible if I change my subscription before the renewal date? Thank You.
Beste antwoord door RBxx
You can change (renew) it 4 months before the renewal date, with different limits. Before that ​​​​​you can change it once per months (higher or lower), but not lower than the original one.
In october 2019 KPN introduced ‘Hussel’ subscriptions and since then it’s also possible to change it (once a month) to a lower option than the one you started the subscription with.
2 reacties
Joris62
  • October 21, 2022
Hi @21051 , you are talking about a mobile subscription , right? You can change (renew) it 4 months before the renewal date, with different limits. Before that you can change it once per months (higher or lower), but not lower than the original one.
RBxx
  • October 21, 2022
