Disable call forwarding and voicemail
  • July 29, 2019
  • 788 keer bekeken
hi there,
I would like to know how to I disable completely:
  1. call forwarding
  2. answering machine
  3. text saying that I have a missed call?
the customer support gave me these shortcodes to try
##21#
##002#
none of which worked. also they didn't know that the answering machine is active but it is since if I call my wife's phone and then I put down ,it goes to answering machine so it's active from KPN.
thanks!
Gabrio
Hi Gabrio, welcome to the forum! For a mobile phone you can disable the voicemail completely by texting the word UIT to 1233.
2 reacties
  • August 7, 2019
yes I got that thanks, done it.
