I didn't receive the activation code for my sim
  • June 7, 2024
  • 194 keer bekeken
I acknowledge that to activate my SIM card, I need to fill in my SIM card number and the activation code. However, I did not find any activation code in the emails from KPN. I kindly request any other methods to solve the problem, thanks!
Hello @Raye Chang, if you didn'’t get the activation code, you can request a new one. If you use this link: https://mijn-bestelling.kpn.com/activatie/resend_actcode/
  • September 17, 2024
Hello , when i put my sim number and my post code , it says that it finds nothing with this number.
i just receive the post-courrier with id verification , i didn’t receive any e mail to activate my sim , what should i do
Normally if you receive the simcard by post courier, the sim is already activated. You can start using the simcard on the date you agreed with us.
Thats what i did , put the sim in my phone , but nothing works
Then there is someting strange going on @Elias40dam, can you fill in your profile? After you've done that, i can look what is going on with your subscription.Â
