iPhone iMessage and Facetime requesting sim card
  • July 30, 2024
  • 123 keer bekeken
So I have an American iPhone 14 so it does not come with a sim card slot like the European iPhones so I have only been using the KPN esim on my phone. 2 days ago I woke up to the notification that I needed to insert my KPN sim card into my phone or else it will expire. I can’t do that if my phone doesn’t have the sim slot. Is the KPN esim doing this? I would imagine that my phone wouldn’t ask for the sim card when it doesn’t have a sim slot. What should I do with my number now? I’m attaching the settings notification and the page that opens up when you open the notification.
Admin: edited message due to privacy concerns.
  • July 30, 2024
Hello @Frederico M.
It seems to be caused by the missing phonenumber in the settings.
You could try the solution I found in this post:
Remove the phonenumber from imessage
Deactivate imessage
Deactivate FaceTime
Restart phone
Activate Imessage
Click the name of the line e.g. ‘Personal’
The phonenumber appears after a while (could take a couple of hours) and it’s stored
Activate facetime
done
Please let us know if this solution still works.
  • July 31, 2024
@Frederico M. You can ask someone (friends or neighbors) to use the SIM card with their phone. But esim does not work with prepaid anyway.
Marcia van KPN
Hi @Frederico M., welcome! Did you try to use the steps GeSp is mentioning? I'm curious if that solves the problem. Please let us know!
