I have the same problem. It is bad for me because I just moved to The Netherlands and do not speak or read Dutch. It is difficult to use the app because it is not available in english and I keep getting that same response when trying to share MBs with my family members. All three phone numbers are listed in app and online though.
*Admin: reactie afgesplitst, eigen topic aangemaakt.
HiÂ
Â
Â
If I click on MBs delen all I get is the message the original poster mentioned no option to pick an amount or recipient. I have updated my forum profile now.
Thank you! I see that you weren't registred for the ‘Hussel privileges’ such as MB's delen. I registered your Internet subscription and also all of the 06-numbers, so it should work in a couple of days! Â
Thank you! I will reply here again if it doesn't work in a few days.
