Multisim activeren lukt niet
  • April 17, 2023
  • 41 keer bekeken
hi @Remco_  - I have the same issue with my apple watch - have been on the phone to KPN for 3 hours and no resolution but I have the same issue prescribed as above - is this something you can help with?
Admin: Split off. Made a separate topic for your question.
Hi @Ricky12345, when I check your number, it seems like everything is active now. Can you confirm this? 😊
  • April 17, 2023
Hi I have the same issue - How did you fix this? I have called but received not help yet
Admin: eigen topic voor vraag aangemaakt
Maja van KPN
  • April 20, 2023
Maja van KPN
  • April 30, 2023
I haven’t heard from you again, so I’m assuming don’t need any more assistance. If you have any other question, please let me know!
  • May 1, 2023
Hi, yes after numerous calls back and forth and a new simcard. The resolution was to delete multi-sim completely and then re order it. Then it managed to delete my ICCID registration within KPN to connect to a new one.
Maja van KPN
Ah, I'm sorry to hear this has caused you so much trouble, but thankfully everything is working correct now!
