Overstappen van Lyca naar KPN
  • dec 21, 2024 8:58 a.m. UTC
  • 239 keer bekeken
I wanted to move to KPN from Lycamobile. It is all started on December 12. First date was 16/12. I couldn't activate my KPN sim card online- because the system didn't recognize my data. Okay. I called to support. They all were honestly trying hard to help. But the date of my transfer was kept changing. From 16/12 to20/12, then to 30/12, to 19/12, to 27/12. I'm 100% sure it will never stop. Someone from the support team told me that it is Lyca's fault, they don't let that transfer happen. I called to Lyca and got the answer that the problem is on the KPN side, that I can go with my number to any provider any time, and I don't have any running contract with them now. Yesterday I've got a new email from KPN saying that Overstapdatum gewijzigd. Op 3 januari 2025 zetten we je mobiele nummer over. Again!!! No one can help me. I was even in a KPN winkel as advised from the support. It is all the same. Best advice was I should keep waiting for the date of the transfer, but this date will never come, the date is keep moving away! I can not say anything bad about people who work in the support team. But the situation is horrible and frustrating. I'm afraid to call to the support because I'm not able to talk calmly anymore((
Beste antwoord door Pieter van Ieperen
First you should get your new KPN subscription sim card activated.
Read: https://www.kpn.com/service/mobiel/simkaart/activeren and follow the steps.
You should end at: https://mijn-bestelling.kpn.com/activatie/ and fill in the form, excluding the 893108 sim digits.
After that, KPN can start the number transfer procedure.
KPN will send a sms to your old Lyca sim, which should be active in your phone.
KPN will wait for your reply, as proof that you really own the number, before continuing the procedure.
In case Lyca blocks you from sending the reply sms to KPN, call KPN again and ask how to proceed.
This is all that I, just a fellow KPN customer, can advise.
Forum|alt.badge.img+3
Maja van KPN
  • dec 24, 2024 10:53 a.m. UTC
I'm sorry to hear it's proving to be so difficult to become a KPN customer ​@SVEsss 😕
Can you please update your profiel and give me a heads up if you’ve done so? I'd like to take a look myself, to see if I can find out what's going on!
  • dec 24, 2024 11:57 a.m. UTC
I have managed to activate my sim card finally👍Would it be possible to move the transfer date from Jan 3d to a closer date? It would be very helpful. If not, it is okay. I have checked my profile, all data is there, what exactly should I change?
Maja van KPN
  • dec 24, 2024 12:34 p.m. UTC
Very good, that's one thing less to worry about!
I don't see any data, did u click ‘sla wijzigingen op’ at the bottom, to save everything?
