Samsung disconnecting from internet
  • June 4, 2019
  • 59 keer bekeken
Hi,
I do have the same problem facing it from day 1. Its annoying that its disconnecting in my Samsung phone at every 1 minute for some seconds.
Admin: afgesplitst van dit topic
Beste antwoord door Bart_
Hey there, @Sree I'm sorry to hear your phone keeps disconnecting. It's different from the original topic in the sense that you have this problem with your mobile phone and the topic starter in the original topic had this issue with his home connection.
But let's have closer look at this issue. Could you tell me a little more about it? Is it just your internet connection or can't you make phone calls anymore too? Does the connection come back by it self? Could you update your KPN Forum profiel with your name, adress, postal code and mobile number? This information in only visible for you and me, as a moderator.
2 reacties
Bart_
  • June 6, 2019
Bart_
  • June 17, 2019
Hi @Sree It's been a while since our last messages. I was wondering if you managed to solve the issue with your phone. Do let me know if you still need help.
