Werkt 5G en Volte op een pixel 6?
  • March 27, 2022
  • 604 keer bekeken
Smir Mj
Nieuwkomer
Pixel 6 pro (android 12) owner here,
Its probably not “officially” supported  by KPN. But using KPN e-sim with a google Pixel 6 phone works for me just fine , i enabled e-sim from the KPN app without any problems :)
Hi! Does 5G and VoLTE work on Pixel 6 in KPN?
admin: eigen topic aangemaakt. Oorspronkelijke topic
Hi @Smir Mj!
If your Pixel 6 is bought for the Dutch/Europese market, 5G should be working. I'm not sure what happens if you use a phone that's made for the Asian market, this might make a difference.
I'm also not sure about VoLTE, but I'm going to ask the right colleague and report back to you when I've received an answer 😊
Hi @Smir Mj, VoLTE will work on a Pixel 6 with a KPN sim card 😊
2 reacties
Maja van KPN
  • March 31, 2022
Hi @Smir Mj!
Maja van KPN
  • March 31, 2022
Hi @Smir Mj!
