Cannot log in to Admin panel
  • January 29, 2023
  • 208 keer bekeken
I am trying to log in to the modem admin gui with no luck. Tried resetting the modem and using the back admin password but unfortunately it doesn’t work. Is there something I can do?
@Nicoar Welcome to our forum.
I assume that you want to log into the Box 12.
Maybe you can translate this topic about the box 12.
Could you let me know if you can login after that?
2 reacties
Rutger van KPN
  • February 1, 2023
  • February 2, 2023
Got it working! thanks
